PWM signal from IMXRT1050 EVK GPIO_AD_B1_06 Pin
Search instead for
sreedevi_mohan
Is there any method to generate PWM signal from  IMXRT1050 EVK  GPIO_AD_B1_06  Pin?
FelipeGarcia
Unfortunately, GPIO_AD_B1_06 does not have any PWM signal alternative option, you can check the muxing options of all pins in chapter 10 of Reference Manual.
Felipe
sreedevi_mohan
we have created a pwm signal using GPT timer example and made a clock with required frequency. But, the frequency is changing at the time of i2c write and read. How the i2c write and read is affecting the gpt timer ?
