PWM not working without XBAR
Search instead for
shaileshnsec
We are trying to generate the PWM signals in imxrt 1050 EVKE evaluation board, not using the QTMR module.
In the example code, XBAR is used for generating signals, if we don't use that, not able to see the signals generated. Checking the signals using logic analyzer.
Can you please suggest me how to disable XBAR and generate PWM signals?
Thanks /Shailesh
gusarambula
Hello Shailesh,
There is not a way to generate the PWM without the XBAR.
I see that you already asked a bit more about this setup on the following thread, so I’m adding it in case another user finds it helpful.
https://community.nxp.com/t5/i-MX-RT/Issue-in-generating-PWM-signal-without-xbar-input/m-p/1288033
My apologies for the inconvenience.
Gustavo
shaileshnsec
Thanks Gustavo.
