OSA_EventWait - Problem with EIQ trying to read from SD card
Alberto_isorna
I'm developing with the IMXRT1064 board.
While trying to load data from the SDcard, using the sdcard_fatfs everything works well.
However, when I try to do the same function that is doing the main inside the TFlite example it can't read from the card, it stays always in OSA_EVENT_WAIT (see picture).
I have well configure the ports, I don't know what is reaminning, could you please help?
Find attached the image,
Alberto.
danielchen
Could you please show me your memory details?  like below picture?
Is the OCRAM or SDRAM your first RAM?
Alberto_isorna
Hello Daniel,
Is the SDRAM:
Actually I found a similar post with a solution and now works for me:
https://community.nxp.com/t5/i-MX-RT/Problem-mounting-FAT-filesystem-using-BOARD-SDRAM/m-p/1091400#M...
The thing is I don't understand why I have to disable the Dcache?
Alberto.
danielchen
