MX RT1176 PXP blend fully transparent color over blue result pink
lukasz_kala
I'm trying to run blending inplace by porterDuffOver function provided by PXP (#i.MXRT1170). PS and OUT buffers are set to the same address, filled by value 0xFF03213A(ARGB) - blue color.
AS Buffer is filled by 0x01000000(ARGB) - fully transparent black.
As result im reciving pink color (0xFF450046(ARGB)) in OUT/PS buffer, but im expecting somthing around original value (0xFF03213A(ARGB)) - blue color.
Could you explain why it is so?
Thanks and bye,
Lucas
Omar_Anguiano
Hello
I hope you are well.
Please check the value of PORTER_DUFF_CTRL register, this controls the blending mode:
Omar
