MIMXRT1064-EVK: Break at address "0x2020b4" with no debug information available, or outside of program code.
zekelandon
Hello Community,
I am trying to run a user developed program which has run time memory allocations in MIMXRT1064 board. I increased SRAM size to fit stack and heap region. Program gets compiled successfully. Once I try to dump and execute, problem occurs with error information as "Break at address "0x2020b4" with no debug information available, or outside of program code". Could someone help me understand and fix this?
Memory details:
Zeke
jeremyzhou
Hi Zeke,
I was wondering if you can share the heap and stack configuration. I think it can help me to figure it out.
TIC
zekelandon
Hi jeremyzhou‌, thanks for showing interest in helping me. I figured out the problem and resolved it. Memory was exceeding the high limit hence the board was not able to identify the memory location ending in throwing errors. I fixed it referring the data sheet and the issue is gone now.
Zeke
rajendrac4u
Hello @zekelandon ,
even i am facing same issue. which memory you are mentioned below. can you let me know how you corrected.
