Hi All
I working with MIMXRT1060-EVK.
And there many mistake in the schematic and MCUXpresso SDK 3-Phase PMSM Control document.
So, I need the latest fixed documents.
Where can I get it?
This is the version I am referring.
3PPMSMCRTUG.pdf:
schematic:
Solved! Go to Solution.
Hi @kenji
A2 is the old version of A3, now the nxp.com just post the A3 schematic, and remove the A2 version, do you have A2 schematic?
This is the A2 Arduino Interface part:
In fact, it is the same as the A3 version.
Do you find any difference when you use it?
As I checked your picture connection:
All the related pins are avaliable in the A2 version.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
Hi @kenji
Please check your MIMXRT1060-EVK board, which SCH-XXX-REV version you are using now, eg, I am using SCH-31357 Rev A2.
You can find the schematic from this link:
https://www.nxp.com/webapp/Download?colCode=MIMXRT1060-EVK-DESIGNFILE-A3
Now, the website is A3 version.
Can't you find the J24,J22,J23 related pins on your MIMXRT1060-EVK board? If yes, please give me a photo of your board.
Wish it helps you!
Kerry
Hi kerryzhou-san
This is my board, SCH-31357 Rev.A2.
I have already seen the schematic of the link.
With that in mind, I said the schematic was wrong.
I want the latest corrected version, newer than the schematic of the link.
For now, only the Arduino Interface part is sufficient.
Hi @kenji
Wish it helps you!
Kerry
Hi All
I want to know the correct pin layout and each pins name of Arduino interface as first of all.
