MIMXRT1050-EVK Error: Wire Ack Fault - target connected?
Search instead for
OmarBengoa
Hi everybody.
I have a board MIMXRT1050-EVK with Display touch, I work with MCU Xpresso IDE 11.3.0.
Yesterday 02 March 2021 all worked fine, but this morning when connected the board to USB on my PC (Windows 10), the board is recognized in my PC correctly but new programs doesn't load on board and an error appears:
Could you help me to resolved this issue?
Thanks.
Sowmiya_R
I am facing same error , could you please help me on this.
yvzblgcyln
My solution was just changing the direction of connection cable on NXP board between nxp board and LPC Link 2. Just reconnect cable on NXP board in the other direction.
I hope it works for you too.
yvzblgcyln
hello sir, did you solve it?
Sowmiya_R
No , could not solve it. Can you suggest some other solution
yvzblgcyln
wops, sorry to heard that. I think there is no other way because i had tried everything, last thing i did was changing cable direction and it had worked for me.. btw i assume that you install all related driver so i wont say to you to install drivers.
