How can I output the current clock speed the MCU is setup for / running at? As the iMXRT1062 comes in Industrial and Consumer versions, and I'd like to state the clock speed right at boot.
Solved! Go to Solution.
1) How can I output the current clock speed the MCU is set up for / running at?
-- In the SDK library, it provides the CLOCK_GetFreq() function to get the clock frequency for a specific clock name, and I've attached its code below.
TIC
TIC
Where's the code?
Sorry, I forgot to attach the code before, and please check it below.
* brief Gets the clock frequency for a specific clock name.
* This function checks the current clock configurations and then calculates
* the clock frequency for a specific clock name defined in clock_name_t.
* param clockName Clock names defined in clock_name_t
* return Clock frequency value in hertz
uint32_t CLOCK_GetFreq(clock_name_t name)
uint32_t freq;
switch (name)
case kCLOCK_CpuClk:
case kCLOCK_AhbClk:
freq = CLOCK_GetAhbFreq();
break;
case kCLOCK_SemcClk:
freq = CLOCK_GetSemcFreq();
break;
case kCLOCK_IpgClk:
freq = CLOCK_GetIpgFreq();
break;
case kCLOCK_PerClk:
freq = CLOCK_GetPerClkFreq();
break;
case kCLOCK_OscClk:
freq = CLOCK_GetOscFreq();
break;
case kCLOCK_RtcClk:
freq = CLOCK_GetRtcFreq();
break;
case kCLOCK_ArmPllClk:
freq = CLOCK_GetPllFreq(kCLOCK_PllArm);
break;
case kCLOCK_Usb1PllClk:
freq = CLOCK_GetPllFreq(kCLOCK_PllUsb1);
break;
case kCLOCK_Usb1PllPfd0Clk:
freq = CLOCK_GetUsb1PfdFreq(kCLOCK_Pfd0);
break;
case kCLOCK_Usb1PllPfd1Clk:
freq = CLOCK_GetUsb1PfdFreq(kCLOCK_Pfd1);
break;
case kCLOCK_Usb1PllPfd2Clk:
freq = CLOCK_GetUsb1PfdFreq(kCLOCK_Pfd2);
break;
case kCLOCK_Usb1PllPfd3Clk:
freq = CLOCK_GetUsb1PfdFreq(kCLOCK_Pfd3);
break;
case kCLOCK_Usb2PllClk:
freq = CLOCK_GetPllFreq(kCLOCK_PllUsb2);
break;
case kCLOCK_SysPllClk:
freq = CLOCK_GetPllFreq(kCLOCK_PllSys);
break;
case kCLOCK_SysPllPfd0Clk:
freq = CLOCK_GetSysPfdFreq(kCLOCK_Pfd0);
break;
case kCLOCK_SysPllPfd1Clk:
freq = CLOCK_GetSysPfdFreq(kCLOCK_Pfd1);
break;
case kCLOCK_SysPllPfd2Clk:
freq = CLOCK_GetSysPfdFreq(kCLOCK_Pfd2);
break;
case kCLOCK_SysPllPfd3Clk:
freq = CLOCK_GetSysPfdFreq(kCLOCK_Pfd3);
break;
case kCLOCK_EnetPll0Clk:
freq = CLOCK_GetPllFreq(kCLOCK_PllEnet);
break;
case kCLOCK_EnetPll1Clk:
freq = CLOCK_GetPllFreq(kCLOCK_PllEnet25M);
break;
case kCLOCK_AudioPllClk:
freq = CLOCK_GetPllFreq(kCLOCK_PllAudio);
break;
case kCLOCK_VideoPllClk:
freq = CLOCK_GetPllFreq(kCLOCK_PllVideo);
break;
default:
freq = 0U;
break;
return freq;
TIC
