LWIP MQTT + TLS + Free Rtos reference code
Search instead for
     Board = imxrt1064 evk board.
     I have implemented mqtt with free rtos code working fine.
     We want to add TLS option nxp side any reference design is available ?
     Can we get any suggestion how to implement mqtt with tls ?
Thanks & Regards,
      Vasu
Hi Vasu,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
To provide the fastest possible support, I'd highly recommend you refer to the mbedtls_examples in the SDK library for details.
TIC
Hi jeremyzhou‌,
        Thank you for your reply.
        I have already refereed evkmimxrt1060_lwip_httpscli_mbedTLS_freertos code it was working fine.
        But we used evkmimxrt1064_lwip_mqtt_freertos example code for our project.
        evkmimxrt1064_lwip_mqtt_freertos this mqtt library supports TLS ?
        Otherwise i have to start own mqtt stack TCP + MQTT + TLS ?
Thanks & Regards,
     Vasu
Hi Vasu,
Thanks for your reply.
1) evkmimxrt1064_lwip_mqtt_freertos this MQTT library supports TLS ?
-- Yes, and the tutorial: Tutorial: Secure TLS Communication with MQTT using mbedTLS on top of lwip | MCU on Eclipse shows how to implement Secure TLS communication via using mbedTLS, please refer to it for details.
TIC
Hi jeremyzhou‌,
       Sorry for the late reply,
       This code based on raw api but we are using freertos.
        Any freertos based example code is available ?
Thanks & Regards,
        Vasu
Hi Vasu,
1) Any Freertos based example code is available?
-- Unfortunately, there's no similar demo code.
TIC
Hi jeremyzhou‌,
       We will try to implement our side.
Thanks & Regards,
      Vasu
