Implement example flexspi_nor_polling_transfer in project based on FreeRTOS
Search instead for
nbe
I try to work with flash memory on MIMXRT1020-EVK
I added files from SDK example, after calling flexspi_nor_flash_init(EXAMPLE_FLEXSPI) my program have an error in line 236, file fsl_flexspi.c.
How to find and fix this problem?
kerryzhou
Hi Nazarii,
  Do you run the official flexspi_nor polling project directly on your side, whether it works or not?
  Besides, if your modified project have problems, it's better to share the whole project which can reproduce the problem, then we can help you to check it more easily.
Kerry
