IMXRT1175 5v input tolerance
henrynguyen
we are looking to design with IMXRT1175 chip and want to make sure that the CAN-RX line and other GPIO INPUT pins are 5v tolerant INPUT or not.  can you please confirm?
Thank,
Henry
diego_charles
Hi @henrynguyen
I hope you are doing great!
In general,  i.MX RT is  GPIO banks do not suppot 5V, the same applies for RT1175. Let me explain my answer below.
Here is an snapshot from the Datasheet. The GPIOs shall not be operated above GPIO bank supply rail rating. In this example NVCC supply rails.
NVCC rails are rated for 3.3v or 1.8v, see the below snapshot from our  MIMXRT1170HDUG.
All the best,
Diego
