We are using the IMXRT1060 EVB and we want to program the board by copying the generated .axf file by copying it on the board mounted storage device. Long story short, this action works (it programs the flash on the controller) but no auto reset is performed, so the user must perform a reset manually. How the autoreset can be enabled automatically on LPC after the .axf has been successfully copied?
Marius
Solved! Go to Solution.
Hi Marius-lucian Andrei ,
for the opportunity to serve you.
The OpenSDA is incapable of doing that currently unless modifying the source code of the firmware (GitHub - ARMmbed/DAPLink ).
So I'd like to suggest you can contact the ARM tech support engineer to guide the modification work.
TIC
Hi jeremyzhou,
The link you provided contains an MSD commands list which helped me to enable the AutoRestart functionality. This link DAPLink/MSD_COMMANDS.md at master · ARMmbed/DAPLink · GitHub might help the others with the same question as I had.
Marius
TIC
