IMXRT1024 UART Terminal Output Issue in Manual Configuration
Search instead for
Lukas_Frank
Hi all,
UART Write and Read operations prints data to terminal screen (serial port configuration) successfully in SDK Pooling Example. But, there is not printing data to terminal screen when I create a project from scratch despite data communication is successfully occur. Why could be my example is not printing to terminal?
Thanks and Regards.
jeremyzhou
According to your statement, it seems like the print function doesn't link to UART Write successful, so I was wondering if you can describe the steps you created for a new project in detail.
TIC
jeremyzhou
TIC
Lukas_Frank
Hi Dear @jeremyzhou,
I will try to link them. Then, I'll turn here again.
Thanks and Regards.
