Hi all,
I am not able to make sense one parameter in IOMUXC_SetPinConfig method in the BOARD_InitPins. It is configValue parameter of IOMUXC_SetPinConfig (sixth-one). I see it assigned as 0x10B0U in the SDK Pooling example. Why? What is the meaning of 0x10B0U. Is there a sheet that explain different combination of this parameter for spesific cases or Is that value constant for all cases?
Thanks and Regards.
Solved! Go to Solution.
1) Is there a sheet that explains the different combinations of this parameter for specific cases or Is that value constant for all cases?
-- To provide the fastest possible support, I'd highly recommend you to learn the meaning of the 0x10B0U by going through SW_PAD_CTL Register in the RM.
Hope it helps.
TIC
Hope it helps.
TIC
Hi Dear @jeremyzhou,
There are exactly 2870(SW_PAD_CTL) and 78(0x10B0). I will look the details and turn here again.
Thanks and Regards.
