Hi all,
I did't see the Data Word size in both Reference Manual and Data Sheet. What size of the one dataword in IMXRT1024? Is it 8 bit or 16 bit? I did not differentiate it.
For example, UART RX/TX FIFOSIZE have OPTİONS from 1 to 256 dataword Buffer size.
Thanks and Regards.
Solved! Go to Solution.
Hello Lukas_Frank,
The size of one data word is 8 bits, and it’s given by the ARM core, which may be why it’s not explicitly stated on the documentation. My apologies for the inconvenience.
Gustavo
Hello Lukas_Frank,
Gustavo
