IMXRT1024 LPUART Transmit Data Register in Fugire
Lukas_Frank
Senior Contributor I
Hi all,
Where is the DATA Register mentioned in IMXRT1024 Reference Manual Section 44.3.4? What is the representation of it in Figure 44-1?
Thanks and Regards.
Alexis_A
Hello @Lukas_Frank,
As it  mention in the UM: Programs store data into the transmit FIFO by writing to the DATA register so it should be before at some point in the FIFO but more detailed information is not available.
Alexis Andalon
Alexis_A
Hello @Lukas_Frank,
Unfortunately, the block diagram in the RM is only a visual representation and more detailed information is not available.
Alexis Andalon
Lukas_Frank
How it can be possible. There is a term in reference manual. But, there is not representation of it. What is the way for accesing more clear way?
Thanks and Regards.
Alexis_A
Hello @Lukas_Frank,
Alexis Andalon
