IAR startup source code
g_volokh
Hi, All.
I see  the startup codes only for GCC in SDK, but I am working with IAR.
Where can I find IAR source code or I should to create it myself?
Thanks in advance.
George.
Labels (4)
jingpan
Hi George,
When you download SDK and select toolchain, add IAR or select all toolchains. Then you will see IAR examples. You can use their startup code.
Jing
g_volokh
Dear Jing,
Thanks a lot, it was very helpful.
George Volokh.
