Hyper Flash on IMX RT1064-EVK does not work
yuripolyakov
On my RT1064-EVK I already made all steps from topic Hyper Flash on IMX RT1060-EVK does not work  but have no result. Is it possible to boot from HyperFlash on this EVK?
p.s. HyperFlash IC after hardware resistor modification (R356, R361-R366) works fine with the example from SDK_2.6.1_EVK-MIMXRT1064\boards\evkmimxrt1064\driver_examples\flexspi\hyper_flash\polling_transfer.
Meera_123
I also configured all the changes of registers but example code(sdk) is not working for me. Can you please guide me?
fangfang
Yes, It is possible.For the detail please refer to the application note https://www.nxp.com/docs/en/application-note/AN12107.pdf.
yuripolyakov
Hi, fangfang.
Thank you for recomendation. I saw this AppNote.
Unfortunately, this is so in theory. . Did you manage to get the result that interests me in practice on this RT1064-EVK? I emphasize, not on the RT1050-EVK and not on the RT1060-EVK.
