How to store data from my RT 1020 Dev Board to my PC
VolcanicCheese
Context:
I am trying to grab data from a device from an Arduino to my Dev Board, but it is an array of 50,000 bytes. I wanted a way to read that 50,000 bytes. If I try to print out all the array, it stops printing out data from the byte once it reaches a certain amount of print statement.
Question:
I was wondering if there was a way to store a big array of something like a text file on my PC?
jeremyzhou
Hi @VolcanicCheese ,
1) I was wondering if there was a way to store a big array of something like a text file on my PC?
-- If you want to store the data permanently, you should write the data to the QSPI flash, otherwise, you can store the data in either RAM or SDRAM.
TIC
VolcanicCheese
Thank you for your response.
I was wondering how I could store the data on my laptop that runs the MCUxpresso IDE?
jeremyzhou
Thanks for your reply and clarification.
1) I was wondering how I could store the data on my laptop that runs the MCUxpresso IDE?
-- In my opinion, it's impossible to save the big data directly via the MCUXpreeo IDE.
TIC
