How to port NFC PN5180 with i.MX RT1050
Search instead for
yen_chen
Hi,all
I need to port PN5180 to RT1050.
Could anyone  support porting guide ?
I add DAL,NxpNfcRdLib,intfs,phOsal for RT1050 now.
If I use PN5180, which file I need to modify ?
FelipeGarcia
Unfortunately, we do not have specific porting guide for PN5180 but I think you can use this guide as reference.
NFC Reader Library Porting to i.MX RT1050 - NXP Community
Felipe
yen_chen
Hi @FelipeGarcia
If I want to set PHDRVIER_PIN in the DAL/boards
How to know the vaule and set ?
Br,
Yen
FelipeGarcia
Hi Yen,
You can see the pins needed by PNEV5180B in the following document. On the RT side you will need to set the pins you are going to use, there are no specific pins just verify that they accomplish the desired functionality.
https://www.nxp.com/docs/en/application-note/AN11908.pdf
Felipe
