I want to use the RT1052 platform to generate a 25Mhz square wave on any chip pin. Because it is not very skilled, it is best to provide a reference program. I am grateful, online, etc.
Hi Op Fancy,
the opportunity to serve you.
To provide the fastest possible support, I'd highly recommend you to refer to the pwm demo which is a simple demonstration program of the SDK PWM driver to view the details.
You can download the SDK library via the below link:
https://mcuxpresso.nxp.com/en/welcome
TIC
