How to generate 25Mhz square wave using RT1052
fancyop
I want to use the RT1052 platform to generate a 25Mhz square wave on any chip pin. Because it is not very skilled, it is best to provide a reference program. I am grateful, online, etc.
jeremyzhou
Hi Op Fancy,
Thank you for your interest in NXP Semiconductor products and
the opportunity to serve you.
To provide the fastest possible support, I'd highly recommend you to refer to the pwm demo which is a simple demonstration program of the SDK PWM driver to view the details.
You can download the SDK library via the below link:
https://mcuxpresso.nxp.com/en/welcome
TIC
