How to change RT1052 LPUART FIFO depth ? The RXFIFOSIZE of FIFO register is read only ????
1,592件の閲覧回数
1277185193
タグ(1)
2 返答(返信)
1,486件の閲覧回数
jimmychan
Yes, this field is read-only. The FIFO size is constant. You cannot set that. Please just use the default value.
1,233件の閲覧回数
FanXinhao
Hi jimmychan, Can i use "Parameter Register (PARAM)" register to change LPUART FIFO depth?
タグ(1)
