How to Interface OV7620 camera with IMXRT1021
jtro
I would like to interface OV7620 camera with IMXRT1020-EVK board. I'd seen user manual section 44.5.8 Camera Interface but couldn't found required information also sample code and interface diagram is not available.
Checked Pin mux but no peripheral available to interface camera.
Any application note and sample source code?
kerryzhou
Hi jtro 9 ,
   RT1021 doesn't have the CSI module, then you need to use the FLEXIO to simulate the camera IF, more details you can check the MIMXRT1020 reference manual, 44.5.8 Camera Interface, then you need to use the related flexIO pins.
Kerry
