How fast QSPI flash XIP comparing to RAM execution in RT1050?
jamesli
What is instructions per second can be achieved in QSPI flash XIP with 133 MHz clock in MIMXRT10xx? What is execution speed ratio in comparing to RAM execution?
Hi Jian
for performance data one can look on
White Paper: Memory Expansion with Adesto EcoXIP and i.MX RT
p.9 sect."UNDERSTANDING XIP PERFORMANCE"
https://www.nxp.com/docs/en/white-paper/NXPADESTOWP.pdf
https://mcu-things.com/blog/imxrt-how-to-coremark-implementation/
With cache enabled, the memories perform very closely to one another.
Hi Jian
jamesli
Hi, Igor:  Thank you very much, that is right answer and I will read them carefully. Thank you for help!
Jian
