I plan to use LPSPI to access the esternal ADC. I would like to have a sampling rate at 500 KHz. I find the module XBARA can provide a hardware trigger for LPSPI.
My question is that if I use this hardware trigger for LPSPI. Do I need to send software command to start SPI communication?
How many transmission would happen after one hardware trigger?
Bo
I have figured out a solution by using QTIMER and DMA. Somehow this issue is solved.
