Get current time on RT1170-EVK
Search instead for
D_Tram23
Good day
I would like to get the current time since the standard Epoch (00:00 01-01-1970) on my RT1170-EVK.
In other words, I want to have the functionality of the time() function from time.h on my board.
This function just returns zero, so I tried other avenues (like the SNVS_HP & SNVS_LP drivers), but nothing could give me the CURRENT time from the Real-Time Clock.
With the SNVS drivers, I can only set a time and calculate differences in time.
Kind regards
D_Tram23
For any other newbies with a similar question:
I realised the solution is to just set the time to the current time using the SNVS_HP/LP driver, as in the example evkmimxrt1170_snvs_lp_srtc_cm4.
As long as the processor is powered, this will give you the 'current' time.
Most final implementations have a small battery to power the LP registers to keep the RTC value ticking.
Kind regards
D_Tram23
Kind regards
