Generate the code for MIMXRT1170-EVK using MCU Expresso IDE.
Ankush_9881
I want to generate the code for MIMXRT1170-EVK using MCU Expresso IDE.
Can anyone help me with stepwise procedure to generate the code.
I have tried to merge the SDKs. But something is missing. Can anyone guide me how to merge the SDKs
Thanks in advance.
kerryzhou
Hi @Ankush_9881 ,
    Thank you for your interest in the NXP MIMXRT Product, I would like to provide service for you.
    To the MCUXPresso IDE generate the code, you can use it's CFG tool.
   You can refer to my post:
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT10xx-SAI-basic-and-SDCard-wave-file-play/ta-p/...
   From chapter 3. SAI MCUXpresso project creation.
   The other peripheral is the same.
   You also can refer to the CFG related document:
https://www.nxp.com/docs/en/user-guide/GSMCUXCTUG.pdf
https://www.nxp.com/docs/en/quick-reference-guide/MCUXDQS.pdf
Wish it helps you!
Kerry
Ankush_9881
Thank you very very much.
kerryzhou
Hi @Ankush_9881 ,
  You are welcome!
   If your question is solved, please help to mark the correct answer to close thise case.
   Any new issues, welcome to create the new question post.
Kerry
