FT5336 driver
Search instead for
FT5336 driver
nxpuserme
I use a RK043FN02H-CT LCD panel to working with the MIMXRT1060-EVK, now I need a FT5336 touch IC driver, please send me if anyone has it. Thanks very much.
jeremyzhou
There's the datasheet of FT5336 and the attachment is the driver of FT5406, please use it as a template and adapt it by referring to the above datasheet.
TIC
