I have 16MiB flash installed and the rootfs volume is listed as 12MiB on kernel boot. Unfortunately the UBIFS file system size is listed as 2MiB. I know df will show less than reality, but this seems excessive.
Actually, I found this was caused by an improper 'c' value used in the MKFS.UBIFS call. Almost have i.mxRT fully functional on Linux.
