Ethernet on i.MX RT1060 will it support both electrical and optical ?
Search instead for
aniketjesu
aniket
jeremyzhou
In the RT1060, the ENET module belongs to the Data link layer in the OSI model, it needs to connect a PHY chip to connect the net, so the ENET module doesn't care about how to transfer the data via either electrical or optical, it's PHY chip's job. ​
TIC
