Ethernet CRS and JTAG TDO pin conflict in i.MXRT1062CVL5A
Search instead for
sumant_s_khalat
Is there any way to get around pin mapping conflict for Ethernet CRS and JTAG TDO in i.MXRT1062CVL5A. Both the pins don't support multiplexing. I have attached a screenshot for reference.
Tags (2)
jeremyzhou
Hi Sumant Khalate
Thanks for your reply.
The i.MX RT1062 supports the SWD interface.
TIC
sumant_s_khalat
Thanks, jeremyzhou, another question on the same lines. Is there any other interface apart from JTAG that I can use to program i.MX RT1062? because I haven't seen SWD on it.
Sumant
jeremyzhou
Hi Sumant Khalate
TIC
jeremyzhou
Hi Sumant Khalate
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
I'm afraid the GPIO_AD_B0_10 is unable to work as JTAG TDO and ENET_CRS pins simultaneously.
TIC
