I am trying to port (convert) some CMSIS-NN code to Hi-Fi DSP calls. However input-output format of Hi-Fi DSP calls are not clear. What is the data format (protobuf, endianness, order) of weights, bias, input parameters of Hi-Fi DSP functions (xa_nn_*) ?
I need to use following functions:
signed int xa_nn_conv2d_std_8x8(signed char *p_out,
signed char *p_inp,
signed char *p_kernel,
signed char *p_bias,
signed int input_height,
signed int input_width,
signed int input_channels,
signed int kernel_height,
signed int kernel_width,
signed int out_channels,
signed int x_stride,
signed int y_stride,
signed int x_padding,
signed int y_padding,
signed int out_height,
signed int out_width,
signed int bias_shift,
signed int acc_shift,
signed int out_data_format,
void *p_handle)
signed int xa_nn_vec_relu_std_8_8(signed char *p_out, const signed char *p_vec, signed int vec_length)
signed int xa_nn_vec_relu_std_32_32(signed int *p_out, const signed int *p_vec, signed int vec_length)
signed int xa_nn_maxpool_8(signed char *p_out,
signed char *p_inp,
signed int inp_data_format,
void *p_scratch)
signed int xa_nn_avgpool_8(signed char *p_out,
signed char *p_inp,
void *p_scratch)
signed int xa_nn_fully_connected_8x8_8(signed char *p_out,
signed char *p_weight,
signed char *p_inp,
signed int weight_depth,
signed int out_depth,
signed int bias_shift)
Tugrul
Solved! Go to Solution.
The above function is from the Cadence HiFi 5 Neural Network Library, please learn the information of these functions via the below link.
https://github.com/foss-xtensa/nnlib-hifi5/tree/master/xa_nnlib/doc
TIC
TIC
