Lab 2 Download Day.
New issue - Connecting to network...
network not found
# wlan-connect abc
Use 'wlan-stat' for current connection status.
app_cb: WLAN: received event 2
app_cb: WLAN: network not found
Hi jim_picariello2,
Do you mean when you operate the LAB2 document, page 21, step 5 and step 6 can't connect to the network, right?
If yes, you need to check your external AP point, you can use the cellphone to share the wifi hotpoint.
Take an example,my cellphone wifi hotpint is:
SSID: AWS
password: kerry123456
This is my test result:
THI
This is my hardware connection:
So, please check your external AP again, make sure it works.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
