I got the following DSP compilation license error.
The error came suddenly, the compile process had worked.
License checkout failed: No such feature exists.
Feature: XTENSA_XCC_TIE
License path: /home/Documents/xtensa_workspace/iMXRT600SDK.lic:/home/xtensa/XtDevTools/install/tools/RI-2020.5-linux/XtensaTools/Tools/lic/license.dat:
FlexNet Licensing error:-5,357
Reinstallation of the Xtensa Xplorer with Getting Started guide does not work.
I tried license file with LAN and WLAN MAC adress.
I followed all the steps in the Getting Started from section 2.7.
Lennart
Hi @Lennart_R ,
I see someone met same problem before. The problem is cause by the name of the network interface. Please try it again.
Jing
