DCDC_LP Not Turning On
dfowler
Hi there,
I have designed a custom board around the MIMXRT1052DVJ6B by referrencing the IMXRT1050-EVKB board.
I have all my supplies up and running. Then PMIC_ON_REQ turns on the DCDC_IN supply and a RC filter goes to DCDC_PSWITCH with plenty of delay, but I never seen any voltage on teh DCDC_LP pins.
Are there any other requirements that I may be missing to get it to turn on?
Thank you
FelipeGarcia
Hi Drew,
I recommend you to check errata ERR011092 of Chip Errata for the i.MX RT1050 document. Maybe that is the issue you are facing.
Felipe
