I have a i.MXRX1170-EVK that has RK055HDMIPI4M TFT display included. Does anyone know how to connect the ribbon cable from the TFT Display board to the .iMXRT1170-EVK MIPI LCD connector?
More specifically, the orientation of the connector?
The TFT Ribbon cable has a blue tab on one side?
I cannot seem to find any installation instructions on this site?
Any help would be greatly appreciated.
Thanks in Advance.
Steve K
Solved! Go to Solution.
Thank you
I just ordered the part from mouser.com. should be here in a couple of days
Hi Steve,
Please go through form pic1 to pic3.
pic1, pull out black part.
pic2, insert the cable.
Pic3, plug the black part.
Jing
hi Jing,
Thanks so much for your help. I understand now how to install the ribbon cable.
I sort of have an issue with the BLACK Part though. When I tried to remove it I broke of one of the end.
The cable still seems to hold fast but, I was wondering if there is a part number for the black part or the entire connector? I could order it online.
Thanks again for your help
here is a BOM table in RT1170 EVK design package. It shows this is "CON 1X40 FPC SMT RA 0.5MM 89H AU". Manufactured by WURTH ELEKTRONIK EISOS GMBH & CO. KG (ELECTRONIC & ELECTROMEHANICAL COMP). Mfg part number is 68714014022.
Thank you
