Can't debug HiFi4 core
Search instead for
Can't debug HiFi4 core on MIMXRT685. I get the following message:
I follow the "Getting Started with Xplore for RT600". Debugging demon is started and the topology.xml file is updated.
Any comments, thoughts or hints will be highly appreciated.
Hi AntonL,
I'm not sure what the error is. Please check the list below:
1. When you start daemon, does it work right? Please compare with page 17 in <Getting Started with Xplore for EVK-MIMXRT600.pdf>
2. Xplore license must be installed?
3. Install build Configuration(section 1.4)
4. Try to install Xplore in default directory.
Jing
Hi AntonL,
Jing
