I am trying to read and write .txt file and .jpg file, which is present in SD card, mounted on imxrt1064 EVK board. In MCUxpresso I am using inbuilt code with emFile System. according to emFile user manual porting all dependencies and all parameters done, but it not able to do FS_Fread() or FS_read().
If any idea about how to access SD card in imxrt1064 from mcuxpresso using emFile system then please share and give any suggestions related to this.
Hello Dhara,
There is not an example for emFile on the SDK. There are, however, some SD card FatFS examples. I mention it in case it may help.
My apologies for the inconvenience.
Gustavo
