Can't access RT 1170 datasheets
Giedrius
Hello, after clicking 'Data sheets' button on https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-... page, I get the following error:
An error occurred while processing your request.
Reference #97.d7da1002.1640815159.58f1f875
The address bar shows:
Giedrius
Thank you for getting back to me - the pdfs do download, but the link still gives me the same errors as in my original post, this time reference number is "#97.d7da1002.1640856893.59f3faf5" (some NXP website pages take a very long time to load for me, but otherwise, my internet connection is fine)
By the way, the datasheets seem to be incomplete and refer to a Reference Manual, and provide a link to https://www.nxp.com/docs/en/reference-manual/IMXRT1170RM.pdf, but the website says the page is not found.
Do you know where is the Reference Manual currently available?
kerryzhou
Hi @Giedrius
  Change the network, whether you can download it or not?
You can see, I can download it.
The RM, please use this link:
https://www.nxp.com/webapp/Download?colCode=IMXRT1170RM
You need to log in first. Then you can download it.
If you still have issues, you can use your phone to share the Hotpoint, then download it again.
Kerry
kerryzhou
Hi @Giedrius ,
  Please click the following link:
Then you can donwload the RT1170 datasheet:
All the related datasheet:
https://www.nxp.com/docs/en/nxp/data-sheets/IMXRT1170IEC.pdf
https://www.nxp.com/docs/en/data-sheet/IMXRT1170CEC.pdf
https://www.nxp.com/docs/en/data-sheet/IMXRT1170AEC.pdf
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
