In NXP mimxtr685-EVK sdk example i tried to use the RED LED-D9 ,Port - 31 while building the sdk example path :nxp_mimxrt685_sdk_v_1_0/source_code/boards/evkmimxrt685/driver_examples/gpio/led_output/armgcc ,getting the build error
Used RED LED port 31,pin D9 in nxp rt600 ,it is not working (blinking)
