Im using Keil Uvision5 as ide ,im struggling with a doubt how sdk and the register level configuration come to a common ground. Because the example codes given in the Keil uvision software and SDK codes do not make any sense , can someone give advice on how to get familiar with the board and learn fast ?
Solved! Go to Solution.
Hi @Charindu_Abeysekara ,
Thanks for your interest in NXP MIMXRT series!
Please follow the Getting Started guide document for the first step to make sure the project in the SDK is ready to run on your board. I'm assuming you've already done this step. https://www.nxp.com/document/guide/getting-started-with-the-i-mx-rt1170-evaluation-kit:GS-MIMXRT1170...
So, the information you want to know is what the software does before executing main()? We suggest you use Keil's debug single-step debugging.
Gavin
Thank you .
Gavin
