A system level question about AN12149, Implementing PTP on i.MX RT
Search instead for
benjamin_p_quin
I was curious how much time it took to complete this original implementation?
Or to rephrase, how long would it take to complete this on a unique board?
Tags (3)
victorjimenez
Hello Ben,
I'm not sure that I understood correctly your question, so please correct me if I'm wrong. You can download the software of that application note from the following link. If with your question you mean how long will it take you to migrate this example to use your custom board instead of the evaluation board, then it won't take you much since you only need to change the pin configurations.
Victor
