32.768kHz Crystal and 24MHz OSC recommendation for the RT1064
shai_b
Senior Contributor II
Hello Team,
My customer is planning to use the following 32.768KHZ and 24Mhz crystals solution with RT1064:
Transko P/N: CS21-F1015CQ08-24.000M-TR
Spec:  https://www.transko.com/img/product/crystal_pdf/cs21.pdf
MicroCrystal P/N:  CM8V-T1A-32.768KHZ-7PF-20PPM-TA-QC
Spec:  https://www.microcrystal.com/fileadmin/Media/Products/32kHz/Datasheet/CM8V-T1A.pdf
Could you please advise if there are any issues to work with the iMX RT family with the above part number?
Waiting for your kind feedback, Thanks a lot.
Shai
kerryzhou
Hi @shai_b ,
  Checked your crystal document, I think it's OK to use, didn't find the issues.
Wish it helps you!
Kerry
kerryzhou
Hi @shai_b ,
Wish it helps you!
Kerry
shai_b
@kerryzhou.
Thank you for your inputs.
KR,
Shai
