26MHz external crystal for RT600
Search instead for
In i.MX RT600 datasheet show the crystal oscillator operating range 1MHz to 25MHz,
but in the description of clock sources, external clock input pin(50MHz Max),
so can I use a 26MHz external crystal for RT600?
Thanks.
No, crystal oscillator operating range 1MHz to 25MHz, SO the customer can not use a 26MHz external crystal for RT600.
External clock input (CLKIN function from a pin, selected by IOCON) is not for the crystal.
Have a nice day.
Thank you
