0 available SWD Devices detected - I found a solution to fix RT1160
neo2
Sharing my solution to a big problem.
Problem: I could not connect to my RT1160 anymore with MCUXpresso to flash/debug my software.
Eventually I stumbled across my own solution.
NXP might be able to explain why this worked
I looked at the SW1 switch - I changed the setting to 0 0 0 1
Then I tried the debug - flash - this worked! CMSIS-DAP link OK
Then I put the setting back to SW1 switch - to 0 0 1 0
Labels (4)
danielchen
HI
Thank you for sharing your solution.
You also can perform a Mass erase for this issue.
km817221
Mass erase does NOT work, I spent 5 hours looking for a solution and this person's feedback worked even for RT1060 dev board. NXP's documentation or lack of has been extremely disappointing.
