time() function holds on software breakpoint
525 次查看
Freddy_
I'm using a MIMXRT1170 EVK Board and a Segger JLINK debugger. I've imported some COTS code that makes use of the time() function.
The issue is that the software holds during the execution of the time() function on some software breakpoint (bkpt 0xAB).
My question is how does the time() function actually gets the time ? Why does the software hold on that breakpoint ?
487 次查看
EdwinHz
Hi @Freddy_,
I wouldn't be able to tell you with certainty how the time() function works, as it is not part of the API functions we provide on our SDK. Further inspections would have to be done on the code you imported, but I would expect it to use the RTC module. As to why the software holds on that breakpoint, it would depend on the implementation of the code that you are using.
BR,
Edwin.
488 次查看
EdwinHz
Hi @Freddy_,
BR,
Edwin.
469 次查看
Freddy_
Thank you for you answer.
Freddy
