"Adding Custom Cluster to RT1060 Matter Thermostat: XML Tool and Compatibility Issues"
pooisonner
I am developing an RT1060 Matter thermostat.
I would like to add a custom cluster.
I need to add or modify an XML file, but I cannot find the relevant tool from NXP.
Nordic provides a tool at https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/matter/getting_started/manufacturer...,
which allows adding attributes or commands.
I tried applying this to NXP, but the format of the generated XML is different, resulting in build errors.
I would appreciate your advice.
Thank you.
Sam_Gao
Please clarify in details, such as SDK version, examples, code link.
'applying this to NXP', which code base is from NXP?
