question on MCAT parameters
1,148件の閲覧回数
michelet1
good morning,
in the last days i tried to make mcat with different motor using MCAT for RT1050 on SDK version 2.9.1
my doubt concerns the fact that during MCAT procedure the Rs,Ld,Lq values are extrapolated and saved in the appconfig.h file.
When i import this .h file into i.mx Quad motor control App project, the #define associated with Rs,Ld,Lq are not used in the code. How is it possible that they are calculated by the MCAT but then not used by the motor control project?
thanks in advance
1,106件の閲覧回数
Hui_Ma
Could you post your question at [Model-Based Design Toolbox (MBDT)] dedicated forum?
Our experts will support that forum. Thank you for the understanding.
Mike
1,107件の閲覧回数
Hui_Ma
Mike
