imxrt1060-evk flexspi-nor debug failed
jingyangxie
Contributor V
I use a 1060-evk board,when I use flexspi_nor link file in iar,it fails:
lucas_cao
Please make sure the boot mode switch is 0010, that means boot from QSPI flash.
Omar_Anguiano
Hello
Hope you are well.
Could you please give more details on the issue you are having? Which example are you trying to debug? Are you using an external debugger or the one in the EVK?
Are you using the latest version of the tools(IDE, SDK)?
Omar
